Slate_CM
Jul 15, 2015Explorer II
To test current draw, amps, you would disconnect the negative terminal. Set the meter for DC amps. There should also be a place on the meter to put the red probe labeled 10A or so.
Then put black lead to the battery negative and the red lead to the negative battery cable. Don't test anything heavy draw like a tongue jack or heater fan. I'm not sure what a TT should draw with everything off, but on a car it should be no more than about 50mA or 0.05 on the meter.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
