JoeH
Jul 10, 2023Explorer III
If you follow the instructions, there will be no power drain unless you use an electrically operated brake system ( e.g. brake buddy or similar) Since you have a DP, I'd recommend a M&G brake kit. Proportional application, operates off the DP's air brakes ( no electric drain) and once installed, it takes only a few seconds to attach when hooking up the toad.
For lights, look on etrailer.... several kits to choose from. Here's one
hopkins tail light kit
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
