RVhiker's avatar
RVhiker
245/75/16 E tires to 265/75/16 E tires
Is there any reason not to change from 245/75/16 E tires to 265/75/16 E tires? I'm considering doing so due to the increase in load capacity from 3042 pounds @80PSI for the 245 tire to 3415 pounds @80PSI for the 265 tire.
I realize that the speedometer will read about 4% slower with the 265 than with the 245 tire.
  • Yes, the recommended rim width (bead to bead) is important, but many mount them
    on the OEM 6.5" rim. There is an OEM 7" rim, but not all have that...most common
    is the 6.5" rim width
    Bead to Bead is the measurement on the 'inside' of the rim...unscrupulous marketing
    uses the 'outside' measurement to make it 'seem' wider than it is
    That narrower rim width creats more sidewall bendback and that increases the
    potential ride quality...but reduces the tire's response characteristics
    Of more concern is that the wheel's weight rating vs the new tires higher weight
    rating
    The wheel spec should be on the wheel somewhere. Suggest the OP check before
    purchasing the higher rated tires
    This is a picture of my Suburban, which has LT265/75R16E's on 16x10
    alloys rated for 3.2K.
    mysub mysuburban
    No reason not to step up a size. I run the 265/16 on my '09 with no ill effects. The speedometer is off by about 1 mph when I'm going 65 mph. Nothing to worry about there either. The tires will cost a little more, but they will carry more, as well as look much better. Go for it.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 06, 2025
