- cencerritaExplorer II
SoundGuy wrote:
cencerrita wrote:
Just taken the covers off the toilet and think I have identified it as a different model - label on the extension for raising the height say it has a part model for a 510+ and the kit you have suggested would then be OK.
If your Dometic toilet is indeed a 510 or 510+ then it's entirely different from the 300 series. Go here and you can download parts breakdowns for the various Dometic toilets.
Thank you that is great :) - cencerritaExplorer II
Chris Bryant wrote:
The 300 series (300, 310,320) are bonded together between the ceramic bowl and base assembly. The 500, 900, and about all of the others are 2 piece with a clamp holding base to bowl. The 300 series was designed after Dometic bought Sealand, and is a good unit, but not the repairability of the other models- built to a budget.
Thank you:) Shame Amazon are out of stock but others come near - Chris_BryantExplorer IIThe 300 series (300, 310,320) are bonded together between the ceramic bowl and base assembly. The 500, 900, and about all of the others are 2 piece with a clamp holding base to bowl. The 300 series was designed after Dometic bought Sealand, and is a good unit, but not the repairability of the other models- built to a budget.
- SoundGuyExplorer
If your Dometic toilet is indeed a 510 or 510+ then it's entirely different from the 300 series. Go here and you can download parts breakdowns for the various Dometic toilets. - cencerritaExplorer IIJust taken the covers off the toilet and think I have identified it as a different model - label on the extension for raising the height say it has a part model for a 510+ and the kit you have suggested would then be OK.
Is the main difference of ID between the 310 and 510 that the 510 has a left flush and metal lever under the plastic covers? (the 310 seems to have a right foot flush from all pictures I have seen)cencerrita wrote:
Thanks. have you actually fitted one as adventurerv.net says it does not fit - this kit has a brass shaft and I know mine is plastic.
"Fits most* pedal-flush VacuFlush, Dometic, Sealand, and Traveler brand toilets with metal pedal. Color is white. Contains: Flush ball, rotor shaft, cartridge, and fasteners (2).
* Does not replace flush ball & shaft on 300, 310, and 320 series Dometic toilets. Metal pedal includes metal lever with 2-piece plastic cover" - SoundGuyExplorer
MrWizard wrote:
Dometic (385318162) Ball and Shaft Kit for Toilet
Fits 300, 310, 320
Incorrect, this will not fit the 300 Sealand series of toilets. The OP is wanting a part that doesn't exist ... if his is damaged his alternative solution is to replace the toilet. :( - MrWizardModeratorNo I have not used this
Just the part number a search turned up - Old-BiscuitExplorer IIIThere ISN'T A Ball/shaft replacement kit for the Sealand 300 Series
The one 'referenced' is NOT for the 300 series (300,310 OR 320)
A SEAL is only part for toilet bowl....NO BALL/SHAFT KIT
"Fits most* and *Does not replace flush ball & shaft on 300, 310, and 320"
are big clues!!! - cencerritaExplorer IIThanks. have you actually fitted one as adventurerv.net says it does not fit - this kit has a brass shaft and I know mine is plastic.
* Does not replace flush ball & shaft on 300, 310, and 320 series Dometic toilets. Metal pedal includes metal lever with 2-piece plastic cover" - MrWizardModeratorDometic (385318162) Ball and Shaft Kit for Toilet
Fits 300, 310, 320
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
