Durb
May 15, 2017Explorer
filrupmark wrote:
Check to see if you have slack between your hitch and your rails . If so Curt makes rubber damper pads that install between the hitch and rails. It is amazing how much noise just 1/8" of slack can make.
Dittos to this. I had the same problem that developed after a number of tows and things got settled in. They are cheap and easy to install. If I recall I looked them up on the Curt website then used the part number to search Amazon. They solved my problem. On my hitch they wear quickly and I have to flip them after the first year so 2 year max.
Search Curt 16900 on Amazon.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
