DazedNConfused's avatar
Sep 02, 2014
A/C built-in thermostat question - A/C not cycling often
Good morning. Camped over the weekend in probably the warmest non-shade temps we've done so far -- around 90-92 degrees. I have a 40-foot 5th wheel with twin A/Cs -- a 15K in the main living space and a 13.5K in the front bedroom.
The main A/C worked like a champ. Ran lots all weekend, but produced nice cool air. My concern is the 13.5K unit. It runs and cools fine when the compressor is cycled...but the issue I am seeing is that the compressor doesn't cycle as much as I'd like for it to. I experimented a bunch this weekend varying the fan speed between low, med, and high....and adjusting the dial-thermostat that's built into the return/blower housing. At the hottest part of the day, the main unit was doing all it could...but I wanted to supplement with the bedroom unit...however it would only run for a minute or two...and then cycle off again. It would cycle from time to time...but maybe only 4 times per hour (I didn't time it).
My camper is stored indoors...and I inspected the coil and such by removing the outside cover...and there wasn't anything obvious going on, nothing looked very dirty, etc.
I did read that some folks say the built-in thermostat being so close to the moving air can cause the compressor to cycle off. Curious what people's thoughts are on this. If this is reasonable or expected, can I wire in a wall-mount thermostat so it's farther away from the unit and bypass the built-in one?
So for the most part the main A/C was doing the bulk of the cooling. As such, it would cycle at 74 or above...but would run non-stop below 74. I was happy with that...but would be happier if I could get the second unit to help share the load more effectively.
Of note, I have a Progressive Industries surge protector installed with a remote display...so I can tell by looking at the second 50-amp leg when the bedroom A/C is just blowing air vs. the compressor also running -- usually a 5amp draw vs. 16 or so amps.
Thanks,
DNC
  • It sounds like it runs so little the stat could actually be faulty.
    There's a couple guys who really know their stuff on here regarding AC units. If you could get the model info, they probably could tell you exactly what to look for.
  • tpi wrote:
    Is the bedroom AC located in a confined space and air rapidly cools and kicks off the thermostat? Somehow recirculating cold air into the thermostat space? If so a remote thermostat could help. If not I'd suspect the thermostat being defective or the probe located improperly. The fact it only runs four times per hour could indicate that. Best to post the make/model and some of the forum experts on AC could chime in.
    I had similar situation in my house where thermostat was much to close to forced air register. The air conditioning would cycle off much too soon-and the solution was relocating the thermostat.
    Yeah...normally at night we'll close the sliding door to the bedroom and then it would certainly be more confined. This weekend I had the bedroom door open..and was hoping air would move to the main cabin. Maybe a small box fan on the steps leading into my bedroom would help. I'll get the make and model this evening and post. I'm not sure exactly what a properly placed probe would look like...but i'll read to see where it's supposed to be and will drop the inside cover and "inspect".
    On the main unit, an inspection showed there was a taping issue between the plenum and the duct-work...so I sealed that up and greatly increased airflow to the vents.
  • Is the bedroom AC located in a confined space and air rapidly cools and kicks off the thermostat? Somehow recirculating cold air into the thermostat space? If so a remote thermostat could help. If not I'd suspect the thermostat being defective or the probe located improperly. The fact it only runs four times per hour could indicate that. Best to post the make/model and some of the forum experts on AC could chime in.
