At home when I am plugged into 15 amp circuit my voltage meter in the rv reads 120 volts. Plugged in at families house it reads 114 volts. With ac on 109 volts. What voltage is safe to run ac?
The AC units are normally rated at 115 volts. They should be able to start and run at 10% less. That would be around 104 volts. I would not run mine less then 109. Problem could arise as converter kicks in or microwave maybe used.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
