1L243Explorer IIAug 13, 2015AC VOLTAGEAt home when I am plugged into 15 amp circuit my voltage meter in the rv reads 120 volts. Plugged in at families house it reads 114 volts. With ac on 109 volts. What voltage is safe to run ac?
Chuck_thehammerExplorerAug 13, 2015take a voltage reading as close to the family fuse box.. then inside your camper.could be from fuse box to camper.. is lacking.remember the LESS Voltage.. the more HEAT is generated by everything using the lower voltage. including the Wiring.
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: May 25, 2024
Related ContentAC Amp/Voltage monitorAC Low Voltage Protection.Coleman-Mach 48008-966 AC large voltage dropAC voltage and line lossHigh AC voltage - Norcold Fridge
