Sparksvonrou
Feb 01, 2018Explorer
Adding a wind generator. Need mounting info
We've been boondocking with solar and it works swell. We wanted to take advantage of the wind that is pretty constant and strong at a few places we stay. We got a 400W unit and it has a swivel flange mount. I can get a flange to bolt it to but am not sure what everyone that has one uses for pipe. What size? 1/2" black iron to small? 1" ? How about aluminum? Once I decide on the pipe size then I can get the flange and get it bolted up. I was thinking of making three 5 foot sections of pipe that screw together with couplings. They could be disassembled and then carried in the back of the Jeep toad. To assemble, screw them together, have a hole drilled through the coupling with a big cotter key to retain it. (one end of the coupling welded permanent). But do I put it against the ladder on the back of the Southwind Storm or make it self standing with guy wires or what? So in summary, wonder about pipe size and material and where you fasten it.
Thanks
Sparks
Thanks
Sparks
