Mroma23's avatar
Mroma23
Advice for a newbie
So in August, sorta of on a whim i bought a 2018 Gulf Stream Friendship 275FBG (29'10") Trailer. The trailer was barely used at all, and our family is really excited to use it. My current truck is a 2014 GMC Sierra 1500, rated to pull 9400lbs and a payload of 1710lbs. If my math works it should be plenty of truck, but would like a second opinion or two. Tongue weight is 690lbs, figured another 100 for Husky Center line setup and 135lbs for fuel, should leave in the 800lb range for me my wife and 4 and 7 year old kids. We all add up to around 450 so think that leaves some room but not a lot for stuff in the truck. The trailer dry weighs 4738 and caps out at 7700lbs. I never plan on towing fully loaded (water tanks and such), but just curious if i am figuring this out right.
I towed it 80miles one way already felt good on highway and did not get blown around. It felt good actually and a couple times I looked in the rear view and forgot it was there.
Any Advice or tips would be appreciated.
  • That 690 lbs hitch weight is the dry hitch weight. The real hitch weight will be closer to 825 - 850 lbs when it's all loaded up ready to go camping (even without water). Other than that, all said and done you're still fine - go camping and enjoy.
  • By "such" i meant sewer and gray water. As far as dry camping idk how much i will do that this year.
    Thanks for the input
  • Take the fuel out of your calculation. Truck fuel is already included in the payload calculation.
  • A full tank of gasoline is included without subtracting from payload. IMO you are within specs. However, traveling the West without a full tank of fresh water eliminates lots of beautiful dry campsites. What’s “such?” So when you do arrive at a campsite with water you want to spend three or four hours sanitizing you fresh water tank? Not fun.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
