kevden
Jan 27, 2014Explorer
Ron Gratz wrote:
I don't know why Equal-I-zer would say to attach trailer and wd to tv first, then air up. There's nothing to that effect stated in their online set up instructions.
Ron
From the owners manual:
Step 1 - Set up Location:
While installing or adjusting the hitch, the tow vehicle and trailer should
be loaded just as they will be while traveling. This includes full propane and
fresh water tanks, and any other cargo the tow vehicle (passengers & gear)
or trailer will carry, including ATVs for toy haulers. Tow vehicle “auto-level”
systems should also be disabled or turned off temporarily.
I am taking "auto-level system" to include rear air suspension. But, this is in the initial setup instructions section.
Airing up first could require more cranking on the tongue jack in order to get the tongue high enough to get the ball under it. (More work if you don't have an electric jack).
I have heard the argument that a proper tv should not need air bags or timbrens or any other suspension upgrade several times on this forum. That is like saying a good driver should not need accessories such as gps, or air conditioning, or specialty tires. While this is true that it should not "need" air bags or timbrens, they are an enhancement or addition that greatly improves the ride and handling of the tv. They make it safer and more enjoyable to drive.
Our previous tv was a chevy avalanche with air bags inside of the rear coil springs. I always connected trailer and wd bars first, then added air. The air bags fixed the porpoising/rocking and made the truck a lot more stable. I did not air them up so much that it raised the truck any. IIRC about 20# is what worked good for my setup.
The Timbrens in our current tv work great too.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
