Campin_LI
Jan 30, 2014Explorer
BarneyS wrote:Agreed. It's a simple system with complicated mechanics. In trying to simplify a response, I ended up explaining it inaccurately. Thanks for pointing it out.Campin LI wrote:
WDH's rely on the trucks rear end sag to work. If the truck is leveled first by airbags, adding a WDH will do nothing because you have no rear end sag to lever up. Snip...
Not quite. The WDH will work no matter if there is rear end sag or not. Sag is not necessarily an indication that a WD hitch is needed. You could replace the springs on the rear of a truck with solid steel bars and prevent any sag at all but there would still be weight removed from the front axle and possible overloading of the receiver and rear axle by the addition of a heavy tongue weight. The WD hitch will help correct that situation.
I agree with most of the rest of your post except that I feel the use of air bags is normally not necessary at all when a WD hitch is properly sized and used. Thank you for your contribution to the discussion. :)
Barney
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
