Campin_LI
Jan 31, 2014Explorer
93Cobra2771 wrote:To the OP. This is correct. You should do this. Maybe one of the reasons they changed to this is that more people are adding things such as airbags to their setups. If you add airbags and then return the front to unhitched height, you may accidentally overload your front by transferring too much weight forward. Keeping this rule of thumb gives you more wiggle room.Campin LI wrote:
snip....Your goal is to get the front fender height back to where it was before you hooked up, but not lower.
Within the last several years, most of the manufacturers have revised their specs and suggest the front height (with bars attached) be half way between the unhitched height and the hitched height. In other words.
37" unhitched
39" hitched without bars
Your goal front height in the above scenario is 38".
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
