Campin LI wrote:I doubt that Ford and others have adopted Front Axle Load Restorations of less than 100% because people are adding things such as airbags.93Cobra2771 wrote:To the OP. This is correct. You should do this. Maybe one of the reasons they changed to this is that more people are adding things such as airbags to their setups. If you add airbags and then return the front to unhitched height, you may accidentally overload your front by transferring too much weight forward. Keeping this rule of thumb gives you more wiggle room.Campin LI wrote:
snip....Your goal is to get the front fender height back to where it was before you hooked up, but not lower.
Within the last several years, most of the manufacturers have revised their specs and suggest the front height (with bars attached) be half way between the unhitched height and the hitched height. In other words.
37" unhitched
39" hitched without bars
Your goal front height in the above scenario is 38".
Even if you use airbags to lift the rear of the TV, the same amount of load must be applied to the WD bars to achieve the same amount of load transfer to the front end. Lifting the rear end with air bags does not make it easier to transfer load to the front -- so I don't see how using air bags would cause people to accidentally overload the front axle.
I believe the change in attitude regarding FALR is because using a WDH to transfer too much load to the front axle can lead to undesirable TV oversteer. Some TV and WDH manufacturers, in the past few years, have changed their WDH adjustment recommendations.
I think the reason Ford, Chevrolet, Toyota, Equal-i-zer, Reese and others have changed their weight distribution specifications is pretty well summed up in this Letter to Editor by Richard H Klein, P E printed in TRAILER BODY BUILDERS Magazine. The comment which specifically addresses front axle load is:
QUOTE
2. The statement “too much tongue weight can force the truck down in the back, causing the front wheels to lift to the point where steering response and braking can be severely decreased” is not the real issue with heavy tongue weights. The real problem is that the tow vehicle's yaw stability, as measured by “understeer gradient”, is severely decreased. This increases the propensity of the tow vehicle to jackknife in turning maneuvers. Specifically, recent full scale testing conducted by the SAE Tow Vehicle Trailer Rating Committee (and now published in SAE J2807), determined that the use of weight distributing hitch torque should be minimized. In fact they recommend that the Front Axle Load Restoration (FALR) not exceed 100% (100% means that the front axle weight is brought back, via weight distribution, to a weight equal to its “no trailer” condition).
UNQUOTE
A related explanation from a representative of the company which manufactures the Equal-i-zer hitch was first posted here. It says:
QUOTE
In the past we had suggested that you should see a small drop on the front suspension. We are always trying to improve things here at Progress – our motto is “Safe and Happy Customers,” and so we are always reviewing our instructions and installation process. Recently, as part of this constant effort our engineers looked more deeply into this aspect of installation. We had always felt that a small drop was a sign that the trailer’s weight was being transferred to the front axle, and that this was essentially a good thing.
As our engineers reviewed the instructions for the last round of renewal of our instructions, the found research results that contradicted our prior thinking. There has been a substantial amount of testing conducted by experts from SAE and the RV Industry Association to find out what will produce the best stability when towing. This towing suggests that you want your front axle’s compression to be close to, but not lower than your free-standing height.
UNQUOTE
Ford says the Front Axle Load Restoration should be approximately 50%.
Chevrolet/GMC says the FALR should be 100%, 50% or 0% depending on TV model and TT weight.
Equal-i-zer says the Front Axle Load Restoration should be between 50% and 100%.
Equal-i-zer's revised instructions specifically state:
Good adjustment:
You have most likely achieved good weight distribution adjustment if your measurements show the following with the trailer coupled and the weight distribution engaged:
1. From the coupled without weight distribution measurement, the front wheel well measurement is at least halfway back to the original uncoupled measurement. See line C on Front Wheel Well Measure Chart.
2. The rear wheel well measurement is somewhere between the uncoupled height, and the coupled with no weight distribution height. It should NEVER be higher than the uncoupled height. See line C on Rear Wheel Well Measure Chart. See Figure 19.
Ron
