Campin_LI
Feb 04, 2014Explorer
RinconVTR wrote:I understand what you are saying but if you have reached the goal of 500 lbs restored to the front axle, the back is wherever it is. If you distribute more weight to the front to raise the back, you will be transferring additional weight to the front axle exceeding the 500 lb goal. You will get the truck level but you will remove more than the goal amount from the rear axle to accomplish that.
I just mentioned previously, Option B is telling me the WDH isn't set up very well if this example requires air in the bags to level out the TV after the WDH is set.
On edit: I screwed up the quote and I don't know how to fix it
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
