Ron_Gratz
Feb 04, 2014Explorer
Campin LI wrote:For the example scenario -- if application of WD caused 500# to be added to the front axle giving -500+500 = 0 net load change, then 750# would be removed from the rear axle giving +1500-750 = +750# net load change. IMO, adding 750# to the rear axle would not cause an unstable ride. Most vehicles, especially trucks, are designed to handle this.
A) Restore unhitched ride height: The only way to accomplish this is to use the airbags to lift the back of the truck so that 1000 lbs is supported solely by the airbags. Then, the WDH would be used to transfer 500 lbs to the front axle. The only way I think you can accomplish this is if you use a scale. I say this because if you hitch up and use the airbags to level the truck before WDH is applied, you would be supporting 1500 lbs. Application of WDH would transfer 500 lbs to the front axle and the back of the truck would be unloaded by 500 lbs and possible raised above unhitched height. This may make for an unstable ride.
If the goal is to restore both front and rear to the unhitched heights, that can be accomplished by trial and error -- using the air bags to help lift the rear while using the WDH adjustments to return the front to its unhitched height.
If you get lucky and add the right amount of air pressure (lifting the rear part of the way to its desired height), adding WD will cause the front to drop to its desired height while causing the rear to rise to its desired height.
By adjusting the WDH last, the final adjustment is to the front end load (height) rather than the rear end height.
Since there are no manufacturer specs for rear end height, it's better to get the front end as close as possible to spec.
B) Level stance: The only way to accomplish this is to apply WDH to transfer 500 lbs to the front axle. Add air to the airbags until the truck is level. The problem is that if you stop here, you may unload the WDH. This is where I ran into “trouble” earlier in this thread, so I will try to be careful in my explanation. When the airbags are pumped up, the angle the hitch bars make with the pavement will change (or lessen), causing the WDH to unload. When the WDH unloads, weight is transferred back to the rear axle and 500 lbs is no longer distributed to the front axle. Therefore, I think the only way you can accomplish this is with the use of a scale.Does "level stance" mean the rear end, when unhitched, is higher than the front? If so, some vehicles take on close to level stance just by adjusting the WDH to return the front end to its unhitched height.
If you need to use the air bags for additional lift, you can use the same procedure as A) to get both front and rear to their desired heights.
C) Stabilize the load: This is my preferred method. The way to accomplish this is to apply WDH and adjust to put 500 lbs on the front axle and keep 1000 lbs on the rear axle. Pump air into the airbags until you just see the rear of the truck rise. In this case, 1000 lbs is supported by the suspension. Uneven road surface, maneuvering, bouncing, etc. is supported by both the rear axle and the airbags. This results in proper weight distribution and greater stability.And, as in A) or B), you could slightly overload the front axle with the WDH and then add enough pressure to bring the front end load (height) back to the desired value. In the process, you would gain some additional "stiffening" of the rear suspension.
Related to 2) above, I explained in A and B above that the only way you can be sure 500 lbs is transferred to the front axle after all is said and done is by use of a scale. The reason is that I think front end rise measurements become inaccurate and should not be relied on to assume the 500 lbs in fact remains transferred to the front axle. With C) above, the measurement of front end rise is not compromised.Bouncing the front and rear up and down a few times before measuring the heights might help to reduce some of the errors.
Ron
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
