FIRE_UP's avatar
FIRE_UP
AirForce 1 brake system vs Ready Brake
Gents,
First off, I've used the Ready Brake system for quite a few years now and for the most part, have been pretty happy with it. That included many years using it with a gas coach. Well, we changed to a Diesel unit about 3 years ago and, basically have worn out both my present tow bar, a Blue Ox Aladdin 7500 # unit and, also we've worn out the Ready Brake actuator. I can push it with my bare hand and, you're not even supposed to be able to do that.
So, I'm quite possibly leaning to a brand new tow bar, possibly the 10,500# Demco unit. The primary reason for that is, we to a 5300#, 2011 GMC Sierra 1500, 4x4 Extended Cab. And, in the back of that truck sits a Rampage motorcycle lift/carrier and, on that lift is an '08 Honda GL1800 Goldwing. Now, the lift hovers around 275-300# and the Wing, right at 900#. So, that 7500# Blue Ox was/is, very close to its limits, 24/7.
So, the Demco unit, which if I was thinking clearly at the time, I could have gotten it for right at $650.00 out the door, at the Winnebago/Itasca Grand National Rally, recently held in Forest City Iowa. But, I wasn't ready to buy yet.
So, with all that said, I've kind of given some thought to the AirForce 1 braking system. Mainly due to the fact that it's air operated, to make a perfectly proportional brake application, directly from the coaches air brakes. And, it's a small unit that is not seen and, there's no setup each and every time you get ready to tow.
T
Now, I've not dug into all the details yet. I'm simply THINKING about this major change and, to those components mentioned. To those of you that may have either one, could you please comment on your experiences and thoughts. I'd surely appreciate it. Thanks way in advance.
Scott
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
