joedekock's avatar
joedekock
Antenna "Booster" question
We are on our first trip with our new 2015 Coachmen Freedeom Express 23QTX. We chose a campground just a half mile from home for the first trip to make sure all was well. Thankfully all has been well for the first 2 nights!
The only issue may or may not be an issue at all. Im not sure why, but I never assumed to check the Television antenna when we bought the RV. It doesnt have the typical crank-up, rotatable bat-wing antenna. It has the bat-wing antenna, however its static. I didnt think this would be a problem, but maybe it is. I found what seems to be the antenna "booster" or amplifier on/off switch but it does not help at all... like nothing noticeable. Because we are a half mile from home, I now the local OTA television stations well and actually use the same bat-wing antenna at my home up 30' on a chimney mount mast and it pulls in all the local digital stations without any issue. I do have an amplifier in line for that antenna as well and its running to two televisions with roughly 100' of coax.
So I am perplexed as to why im only getting half the channels on the new Coachmen and that this on/off switch with a little red light does not do anything. So I removed the faceplate with this on/off switch and found there are three coax connections in there, and one is labled "ant" and one "TV1" and the "iv1". For grins, I unplugged all three to see if I lost reception to the television but I did not lose reception at all! So I am hoping someone here can guide me. I have attached two pics. One with the faceplate off showeing the coax connections behind it, and one of the front with the switch and red light. Can someone tell me what it does? Is it possible this is the on off switch for the amplifier and it was wired wrong? Perhaps the television is split inside the wall and coming directly from the antenna?
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
