Dozer's avatar
Dozer
Anti sway question.
If a truck has built in sway control, (2022 Ford Ranger) is anything else necessary regarding a hitch setup? If you're within the guidelines of the manufacturer re: tongue weight. What else needs to be done?
The truck is rated to tow 7500 lbs and I'm only planning to tow about 4500.
Thanks in advance,
Dozer
  • Grit dog wrote:
    Sjm9911 wrote:
    Im for a wdh with sway controll also. Even if you dont have sway, you never know when something out of the ordinary can happen and it saves you.
    ..No matter how many "professional" RVers claim that belt, suspenders, elastic waist band and 2 hands firmly grasping your belt loops is required to safely tow a trailer, it’s not magical or mysterious. And if you’re in that OH SHT swerve to save your life, if you swerve hard enough to get the trailer to break loose, a wdh isn’t going to tip the odds your way very much.
    Again, sway control is for people who are uncomfortable with how a “normal” trailer feels or who have an ill mannered trailer. And a wdh is for if you don’t have enough suspension, or hitch capacity to do the job without a suspension aide.
    To a point. It atucally saved my ass when a consteution barrel was shot out at me on the delaware memorial bridge. If it wasnt for the sway controll, i would have been out a TV and TT. My truck is overkill for what I need, but the sway controll arms kept me from a crash. Running over a barrel at 55 , in between 18 wheelers , and then needeing to slow and swerve to recover wasnt fun. While this is the worst case senerio, it does happen. Barrel, also took out the TT brake lines and ripped off the dimond plate on the front of the TT before the TT tires went over it on the drivers side. So, brakes we no help here.
  • I think it also comes from your experiance with things. What i experianced and worked for me may not be what others have experienced. So, we give advice that is limited to what we know. I still think a sway controll is better then not having one. And as stated , the built in one only helps after you start swaying to begin with. I rather not sway at all. I also think a wdh with the built in sway controller is a good option.
    Yes that is unfortunate. And more common than you may think. I presume you meant construction barrel ie traffic control barrel.
    Those get clipped and sent into traffic semi regularly on any highway lane closure. Quick count probably lost about 30 barrels this summer on just one job. About 3 months of nightly lane closures. Just a swag based on the pile of mashed barrels in the staging yard.
    I understand it scared you. But like seeing a deer in the headlights, if ya can’t stop, don’t swerve. It’s unfortunate it got tangled up in the trailer.
    Just like sjm said above. It’s peace of mind and differing experiences or experience levels that form “our” opinions. However some folks proverbially live with blinders on and refuse to accept opinions or fact, of which they do not recognize as it doesn’t fit into their pre determined opinions.
  • No. The system is always on and waiting to work. I have it on my Explorer and it works. Towing a 3 place snowmobile trailer. Hit a section of ice and you can feel the system working. Very impressive.
  • Like any add ons/tow vehicle options for sway/suspension help/etc you have the truck so buy the trailer you want then load it all up and make a short run. If the combo doesn't behave the way it should then add a WD system.
  • sway control devices are nothing but a compensation for a imporperly loaded trailer. yes I like some of the saftey features being built into trucks now days but as it was mentioned before that is for regaining controle once the sway starts in an atempt to minimize the risk to life if it has gone to far.
    the best way to prevent sway id to load the trailer properly with 10 to 15% (for conventional tow) of the total trailers weight on the ball. if your hitch is rated for 1000 lbs you dont need a equalizer to tow 700lbs, it wont help with sway much, but it may make the ride a little more confertable by reducing the forward/backwards rocking of the truck and trailer every time you hit a bump or dip in the road.
    in 39 years of towing I only ever had sway once and it was my own fault as I had less weight in the front to make it easier to load on the truck (front jack was broken) after that trip the jack got fixed and it was always loaded properly.
  • Those sway control systems are reactive vs proactive. WDH is proactive.
  • Trailer PITCH (severe misalignment with TV) is enough reason. Drop the curbside off the edge while in a high speed curve. Trailer is heading (mass) one way while TV going another.
    The force of the LEVER on the TV (ball back to trailer axles) is the thing. SPREADING that force via leverage (torsion bar) across all three axles DAMPENS the force.
    Keeping the TV rear axle PLANTED is the game. Those two barely one-foot square tire contact patches.
    WDH is cheap AND effective if set up correctly (TV Steer Axle weight same solo or hitched with same TV load both weighings). Travel trailers are tall and have HUGE SAIL AREA. Most loss of control accidents involve high winds or gusts, natural or man-made. (Low COG construction materials trailers aren’t comparable).
    You want to ELIMINATE sway, get a Hensley-patented hitch. Makes all other types obsolete.
  • I used to tow a 4,000 lb TT with a 2003 Ford Explorer. The dealer sold me a cheap Husky WD hitch with no sway control. I was going down a long hill and not watching my speed and I could feel the trailer pushing and next thing I knew, I was going 70 mph. When I tried to slow down, the trailer started violently swaying back and forth. I steered straight ahead and hoped for the the best as the trailer dragged me from side to side. I made it to the bottom of the hill and regained control and immediately pulled over. I had two flat tires on the trailer and left huge skid marks from side to side of the hill. Fortunately, there was no oncoming traffic.
    My point is, if you get weight distribution, don't stop there and get sway control too. I put an Equal-i-zer hitch on it and never had another problem, even when in 50 mph cross winds. I just towed my new 33' trailer through eastern WY with 50+ crosswind warning and no problems with my 10,000 rated Equal-i-zer hitch.
