dcason's avatar
dcason
Are most toilets pretty much interchangeable
Thetford Aqua Magic Style II - the plastic pin that makes the flap in toilet open and close broke so it is either open or closed. Hubby is using a screwdriver to manually push the mechanism.
Is there a better pedal operated toilet that we can get....reviews on these are not great. We need one ASAP because we live in it...not even going to do the warranty. Could we pretty much replace with any rv toilet. I DO want a china bowl though as we had plastic on previous rv and didn't like that at all.
Donna
  • The floor flange has to be rotated or modified on some models.
    The toilets mounting bolt locations are different.
    I changed our toilet out to a Thetford Bravura.
    Another minor issue is the length of the freshwater feed. It may need to be extended.
  • The Dometic 310 is what I have, and generally considered to be good quality by most. I like it, and no problems at all.
    Jerry
  • Yes any RV toilet will work. As for quality I can not help much, other than this may be one of those where the price mean a better toilet.
    Good Luck
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 17, 2025
