- BarneySExplorer III
Campfire Time wrote:
Bobbo wrote:
Measure the distance from the ground to the top point of the front wheel well, both before and after hooking up the trailer. If there is more than 1/2 inch difference, you need WD.
X2! Rear squat is not an indicator that a WDH is needed.
Even a fairly light trailer with a 150/1500 series truck can take enough weigh off the front to require a WDH.
He did not mention nor was he talking about rear squat. He was talking about the RISE of the front fender which would indicate weight being removed from the front axle.
Barney - BoomerwepsExplorerYou don't even need trailer brakes in my state, PA, at under 3K#!
Need a WDH? Depends on the truck. My SIL's Ram 2500 diesel rips his 5-6K toy hauler around no prob with no WDH.
With my former TV, a Ford Explorer, a fully loaded cargo trailer at 3-3.5K# porpoised like crazy. With my near 4K# TT and a WDH, no porpoising and towed in straightaways like the TV & TT were one unit. Made me wish I tried a WDH with my cargo trailer.
I may not NEED a WDH with the new F150 but I plan on using it for the solid feel I had with it before. - Grit_dogNavigator
Negative ghost rider. Unless said 150/1500 truck has the super trailer 3000lb springs or some aftermarket help in back.
If you do the math 500lbs giver take on the hitch doesn’t take much st all off the front axle. - Grit_dogNavigator
IdaD wrote:
I don't think you'd need a WDH for a 2600 lb trailer.
Agree, you don’t even have enough tongue weight to crank down at all on a wdh.
The issue is likely more akin to your expectations than a problem.
Trailer on.... - Campfire_TimeExplorer
Even a fairly light trailer with a 150/1500 series truck can take enough weigh off the front to require a WDH. - LwiddisExplorer IIIf the trailer weighs 50% or more of the tow vehicle IMO.
- ppineExplorer III agree that you should start with the label on your trailer hitch. If you are within specs, then hook up your rig on a level surface and measure how far out of level you are. Measure from the top of the fender well front and rear, unloaded vs loaded.
IN practical terms, I had a hybrid trailer that only weighed around 3500 pounds. No WD hitch needed. My new trailer is around 5,500 pounds and I use a WD hitch. The older Class III hitch is only rated for 5,000 pounds without. - IdaDExplorerI don't think you'd need a WDH for a 2600 lb trailer.
- BobboExplorer IIMeasure the distance from the ground to the top point of the front wheel well, both before and after hooking up the trailer. If there is more than 1/2 inch difference, you need WD.
- bikendanExplorerRead the Towing section of your truck's owners manual.
As was said above, 500lbs+ of tongue weight requires a WDH.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 09, 2025
