willald
Aug 25, 2016Explorer II
1968mooney wrote:
....Just remove the old motor and google the number on it. It will reference to the replacement motor. I purchased mine from Autozone and it came with a lifetime warranty.
The motor on mine is such that I don't think you can remove and replace just 'the motor'. Its a complete assembly, includes the end piece to the awning arm, the cap that goes on end of roller, etc. It looks like THIS.
You're not going to find anything like that from Autozone, or off a car door's power window. It is going to have to be ordered from a RV parts retailer.
That is, unless you were to take the whole assembly apart, separate the motor, find a replacement motor, and try to put that replacement motor back on this assembly properly. No way am I going to try that, I'd never get it back together right, haha.
I contacted Dometic directly, they want $408 for a replacement motor/drive assembly (oouch!). Fortunately, they gave me the part # for this drive assembly. A quick Google search on that part # brought up several different RV parts retailers (Tweetys, PPL Motorhomes, Pacific RV parts to name a few) that have this part for considerably less $$, around $300 (new). I've found several other alternatives as well (reconditioned, and ones that were salvaged off damaged awnings), for considerably less, around $100-200. Will probably go that route.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
