JohnG3
Sep 04, 2016Explorer II
We have a 9100 Dometic awning and just changed the fabric which entailed removing the motor. The advice to get a pop rivet gun is spot on as the pop rivets are 3/16 with large a round flange. The aluminum roller is very thin and may not hold up to the forces developed by the motor. Mark the position of the end tube on the roller. If you do not replace the motor assembly in the proper indexed position the awning will not unroll to the proper length (don't ask me how I learned this info). All technical instructions are available on line.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
