TyroneandGladys's avatar
Dec 29, 2016
Battery disconnect switches
I see that there are two types of battery disconnect switches a knife blade type and a knob style. Would appreciate your comments about your experience with either one.
  • Gjac's avatar
    Gjac
    Explorer III
    bob_nestor wrote:
    the2sharps wrote:
    I tow a 2015 Ford Focus four down. The last step to prepare the car to tow is to disconnect the negative cable from the battery. I mounted a knob style switch under the hood for the disconnect.
    I used a knob style switch that came with my Cool Tech wire harness but discovered that it would corrode and fail to make a good connection with the battery. Replaced it with a sealed switch that I got at AutoZone and haven't had problems since.
    I used the knob style from HF and had the same problem. After cleaning the corrosion twice because my engine had no power to start I realized that the knob was unscrewing slightly due to road vibrations and was arcing and contributing to the corrosive buildup.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
