Skipg's avatar
Skipg
Explorer II
Oct 27, 2014
Battery on or off ??
When plugged into 50 amp shore power during storage should I flip the the battery disconnect switch to the off position or leave it on? Or does it matter? Thanks
Skip
  • coolbreeze01 wrote:
    For storage, I wouldn't leave it plugged into shore power and I would disconnect the battery's.
    Why?:h Care to elaborate?
    Ron
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The answer depends on your converter.. If you have a good quality 3-stage + converter such as a Progressive Dynamics charge wizard unit or an Iota with IQ-4, Leave it connected.. That is how I did it when this rig was new and the batteries lasted 4 years that way and five more full timing it. (9 total) Before we went full time I only added distilled water on Mother's day.
    IF, on the other hand you have a low end single stage.. Well, Some of those tend to overcharge, some undercharge, none do it right.
    I would hope a 50 amp rig has a good 3-stage.
  • 2112's avatar
    2112
    Explorer II
    I'm from the old school when converters were not so sophisticated as chargers. I turn mine on Saturday morning and off Sunday evening unless I'm using it that weekend. I have boiled a battery or two in years passed and have trained myself to do as stated above. I know I don't NEED to but I still do.
  • If you have a three or four stage converter, leave it connected so it will maintain the batteries.
  • smkettner wrote:
    If you are plugged in why not keep the battery charged?
    Exactly, that is one of the reasons I keep it plugged in. All Batteries are charged and ready to go when I am. I do have a BIRD that keeps all of them charged, Chassis and Coach.
  • For storage, I wouldn't leave it plugged into shore power and I would disconnect the battery's.
  • What I do is leave the battery disconnect switch (in battery compartment) in the on position. However, I typically turn on most of the lights in the motor home and then when leaving, i will turn the salesman's switch off. This allows me to reduce the 12vdc amperage draw on the batteries when I'm not in it, and also I can turn on all the lights with one switch.
    Ron
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
