Campinfan's avatar
Campinfan
Explorer III
Aug 16, 2023
Battery Size (replacing)
I need to replace my RV battery. It is a 24DC model. I know that does not mean 24 volts DC. I see a 24DC battery I can get but there is also a 27DC that has more MCA (not sure what that means but I am used to CCA--cold cranking amps) So my question is, can I replace it with the bigger battery and if so, is it worth it to get the additional 60 MCA for $4 more? Just not sure if I HAVE to use the same size or is that just the minimum one the manufacturer uses to save a couple bucks.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
