flapbreaker
Apr 10, 2014Explorer
Ok, I've confirmed that approx 14 volts are leaving the converter but only ~6 is showing up at the batteries (cables disconnected and measurement is through these cables). If I run the generator (in order to do this I have to start the coach) then the terminals receive the full ~14 volts. I checked the cables at the generator and hydraulic slide pump and they are getting the same ~ 6 volts when plugged into shore power and the battery disconnected. I'm a bit perplexed as to where this voltage drop would come from or what to check next...
