SHRED's avatar
SHRED
Bluetooth Battery Monitor
For ease of installation I'm looking for input on Bluetooth battery monitors.
Any that you are satisfied with.
Thanks.
  • 2oldman wrote:
    dodge guy wrote:
    But if the Bluetooth is anything like the bluetooth in my Hughes Watchdog protector you need to be within 10ft of it. Makes it being Bluetooth kind of worthless.
    Yep. Like having to go sit near the wifi antenna to get anything done.
    The one complaint I have about my Victron is the warning buzzer. It only seems to work at the physical unit itself, which is in the battery compartment where I can't hear it.
    If you want a louder buzzer (or flashing light of whatever) you can use the relay contacts on the BMV to activate a buzzer/light/siren in the location of your choice. It is easy to set them up to switch on with the buzzer.
    Unfortunately the phone app can only talk to the unit when it is open and connected, thus it would be very hard to have a bluetooth based buzzer/alert.
  • dodge guy wrote:
    This is the one I have my eye in when I go solar.
    Battery monitor
    Will from DIY solar with Will Prouse gave it a pretty good review as did most buyers on Amazon.
    Sorry, this is not a Bluetooth unit, just seen the title to the post again. But if the Bluetooth is anything like the bluetooth in my Hughes Watchdog protector you need to be within 10ft of it. Makes it being Bluetooth kind of worthless.
  • This is the one I have my eye in when I go solar.
    Battery monitor
  • Ivylog's avatar
    Ivylog
    Explorer III
    Doubt after a couple of trips you’ll be monitoring all that often. I opted for a $42, 500 amp monitor for my 600AH of DIY Lithium batteries. Once the BMS stopped charging them I set the AH to 900AH... it keeps track of usage, %, charge/discharge amps, and voltage...all the info I need. Helped that the display was easy to locate in the BR.
    Monitor
    https://www.amazon.com/CAMWAY-Voltmeter-Backlight-Waterproof-Motorhome/dp/B088RG27LS/ref=mp_s_a_1_10?dchild=1&keywords=aili+500a+battery+monitor&qid=1622487745&sprefix=aili+&sr=8-10
  • If you just want bluetooth (ie no hardware display) then the Victron Smartshunt is the ticket. If you want a display as well as bluetooth then the Victron BMV-712 is the way to go.
  • Hard to beat the Victron BMV-700. It does require a shunt on the negative side, and a + power supply. Not difficult.
    Post may get moved to tech issues or technology.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
