AMG1978's avatar
AMG1978
Bought new TT today, 2016 Stealth, worried I cant pull it!
Today I bought a 2016 Forest River Stealth WA2916 toy hauler. I have a 2015 Ford F-150 3.5L EcoBoost, 6.5' bed, 4x4, SuperCrew, MaxTow package, 3.55 axle, 157" wheelbase. ford site: http://www.ford.com/resources/ford/general/pdf/towingguides/15RV&TT_Ford_F150_r1_Jan12.pdf
My truck shows with a full 36 gallon tank, I have a payload of 1630lbs (with a full tank, @ 300lbs of fuel). Ford.com shows my maximum loaded trailer weight of 11,700lbs. I planned on using an Anderson WDH with "no-sway". I haven't bought it yet, but will. I used a ProSeries bar unit on my current TT, and it was noisy, heavy, and couldn't back up. Want something better. (http://www.amazon.com/Andersen-3380-Distribution-Universal-Brackets/dp/B006X21BH0).
My truck has AirLift airbags installed too. I do not plan on having anything in the bed of the truck, simply myself, my wife, son, daughter and dog in the cab. In the rear of the toy hauler, I thought any weight REAR of the axles (dirt bikes, boxes, gear, etc.) may reduce the hitch weight, am I grasping on this one? I definitely have no plans to load it up anywhere near the max. I don't own sand rails or quads, just a few motorcycles and normal gear. We keep minimal water in it until we get to close to where we are going, or where we are going directly, then fill 'er up.
My biggest concern right now is the hitch weight on their site shows 1025lbs, I can't say what the ACTUAL hitch weight is on this model, it hasn't been delivered to the dealer yet, but we did sign papers and put $1,000 down.
Am I crazy?
Do I scramble this week to trade my F-150 in on an F-250?
I might add, that I am replacing my 25' TT that weighs about 1/2 dry (4000'ish) and a 500lb hitch weight. I pulled it with ease.
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
  • Can't give you good news either. You could be looking at around 1400 lbs of tongue weight alone when trip ready loaded...
    You have a really nice truck, but not for that trailer.
    Just asking...did the dealer tell you that you could, "pull it - no problem."
  • The tongue weight is dry and empty. Your tanks are probably forward of the trailer axles, they will add to tongue weight, and the cargo will remove from tongue weight. But - with a GVWR of 12100 lbs you can count on at least 1200 lbs of loaded tongue weight, so yes, I would be worried. FWIW the maximum tongue weight with weight distribution on my F250 is 1200 lbs. I do indeed think that little F150 with almost the smallest engine package is going to be the wrong truck for that trailer.
    Brian
  • In my opinion, you have good reason to be worried. That is simply too much trailer for a 150 series truck. The tongue weight is going to be too much for your truck once you have it ready to go camping. Get the new truck. You know you want one! :)
    Also, I am not so sure an Andersen hitch would be the best choice for that trailer. The tongue weight is too high for effective weight distribution with that hitch in my opinion.
    Barney
  • I would buy a 3/4 ton and even consider a one ton. If you do upgrade the truck would you actually consider a larger TH as well? You may have been holding back on the rig size because of the 150's capabilities. It's cheaper to hit the sweet spot the first time no matter how painful it may seem now.
  • I once was in your shoes. I did pull all over the place but I was not happy with the truck's performance. I was always adding stuff to make it tow better. a friend of mine told me I should have bought a 3/4 ton. my son was in a wreck,(minor), and I used that as an excuse to update truck to a 3/4 ton, boy was my friend right, 3/4 ton ran circles around the 1/2 ton. I just wish he would have told me sooner.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
