fj12ryder
Dec 08, 2014Explorer III
Ron3rd wrote:That's what I thought too, but if someone made a mistake and started to remove the brake parts but then remembered they didn't have to do that to repack the bearings, maybe they forgot to replace the nuts, since it wasn't something normally done when packing bearings.
Don't know why CW would have removed any bolts to repack the bearings, not necessary and it doesn't make sense to do so.
Normally, there are 4 bolts that hold the brake's backing plate onto the axle. No need to remove unless you're replacing the brake assembly. Has nothing to do with the bearings.
The bigger question is why CW did not notice the bolts missing and notify you.
Yeah, a bit of a stretch. :) Grasping at straws doncha know.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
