Brent_and_Gina
Aug 12, 2015Explorer
Buck50HD wrote:
The brakes on our 5th have never had enough power to lock on pavement. I even increased the wire size to help with voltage drop. That got it to lock on gravel but not on pavement.
We have the lippert "4400" lb axles that are basically a 3500lb axle with a larger diameter tube to minimize deflection under load. This means 3500lb brakes (10" dia) and bearings that are maxed out. Just had a bearing failure after 2 yrs and 5k miles so I'm not a big Lippert fan at the moment.
If your axles are near max rating, they may never lock.
I think you are right Buck. I'm likely not going to get them to lock up. It was mentioned in my RV Owner's Forum as well. Still, I am hoping for better braking.
Brent
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
