Larry-D's avatar
Larry-D
Explorer II
Nov 26, 2017
Broken Anderson Leveler
I've seen a lot of good things said about Anderson Levelers here and after a couple of years I bought a pair. 1st time out using only one on a single axle Rpod travel trailer it worked great. 2nd time out using a pair on a twin axle 28' travel trailer one of them broke. The one that broke was on the back axle and as it was coming down off the leveler it broke in half, at the same point where I have seen photographs of others breaking.
The temperature was approximately 55 degrees so it wasn't a freezing/brittle issue. It did not get caught on anything. It was rotating upward as the trailer was pulling forward and simply broke. The trailer certainly wasn't overloaded and the other leveler did fine. It looks to me that too much material is removed, or not injected in the manufacturing process since from other's photographs the break is in the same location.
Just wondering if others have had the same issue. I've sent a "question" to Anderson. They have a one-year warranty and these were purchased two months ago. Couldn't file a "warranty claim" online since our address of 37 years was "invalid". Got to love modern technology.
  • I've heard about it before although usually with a bigger rig then yours. If I remember right, Anderson is good about replacing them.
  • I've been using a set for about 4 years now. Only 1/2 a season on our new, heavier TT though. The old TT weighed in at about 7200# and we never had any problem with them.
    Time will tell if our new TT which has about 8700~9300 on the axles will stress the Andersons over time but they've been OK so far.
    I wonder if there's something one could fill the cavities with that wouldn't be too heavy but would reinforce them.
Looking for advice before your next adventure? Look no further.25,166 PostsLatest Activity: Oct 02, 2025
