Dutch_12078
Mar 21, 2017Explorer III
Ivylog wrote:Dutch_12078 wrote:
That homemade version linked above may be cheap, but it's also not doing the job as well as the Gen-turi does.
Not only does it do as well, it does better as it has more volume which mixes more air making it run cooler.
On edit: My comments below referred to the dryer hose version shown in holstein13's photo that your link brings up. My apologies for the confusion. I expect your version works fine...
Installed as shown in your post, it doesn't get the fumes up high enough where the prevailing breeze can carry them away, nor will it carry the exhaust noise high enough to be effective for noise reduction. Heat rises, and that loop down on the ground is limiting the flow rate of the air. It could be effective, if the hose was run vertically up the side of the coach to a point a bit above the roof without the downward loop.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
