Sam_Spade
Mar 22, 2017Explorer
Ivylog wrote:
Not only does it do as well, it does better as it has more volume which mixes more air making it run cooler.
I think your analysis is off a bit.
IF the gasses going up the pipe cool off too much the efficient upward flow will be disrupted......sometimes to the point that part of the exhaust "spills" out at the bottom.
The Genturi has the exhaust exiting the "sealed" exhaust pipe pointing UP for a reason.....with the cold air vents also in a vertical direction.
Your setup likely is not NEARLY as efficient as you think it is.
But it still is way better than nothing.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
