L_and_J__Waters's avatar
Aug 31, 2016
Can a higher receiver cause sway?
Question for you engineers and/or physics minded persons. Can a higher receiver position cause unwanted sway issues. Just got a 2013 Suburban 1500 with 8100lb tow package and I now have sway issues. Previous TVs include 04 Tahoe & 05 Suburban 1500 (26' TT, 6000lbs fully loaded) I did not have sway issues with 2 prior TVs. Setup has been the same with all 3 TVs. Been to the scales and all is well with about 11% tongue weight now. Only difference I can come up with is the factory receiver on the 2013 Burb is mounted on the end of the frame. Hence, about 7-8 inches higher than the others. I had to get an extended drop for my Equalizer to keep the trailer level. Just wondering if the leverage from that height could possibly contribute to sway issues? Wind and passing trucks are the primary problem.
Looking for advice before your next adventure? Look no further.25,141 PostsLatest Activity: Jun 14, 2025
