N-Trouble
Dec 18, 2014Explorer
You add/remove washers to ensure your bars are PARALLEL to your trailer tongue when under tension. First determine how many chain links are needed to be parallel, THEN add/remove washers until tension is correct.
I see so many people driving down the road with their bars pulled all the way up to the trailer tongue with about only two links on the chain in order to get the tension they feel they need. THIS should be avoided...
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 09, 2026
