katoom400's avatar
katoom400
check my wdh numbers please
Just getting my new f250 setup with my Outback 250rs, previously I was pulling with a 2010 Tundra and the dealer had setup the hitch. The Ford is quite a bit taller than the Toyota so I had to drop the hitch to the lowest holes in the shank.
Here are my measurements:
Truck only
Front 41 1/2"
Rear 42 3/4"
Truck w/trailer and NO WD
Front 41 5/8" (only went up 1/8")
Rear 41 1/4" (dropped 1.5")
Truck w/trailer and WD
Front 41 1/2" (back to unloaded height
Rear 41 1/2" (1 1/4" sag)
in the following pics you can see it seems to sit pretty level, from the left side the trailer looks slightly nose down, but that could simply be the pavement it's sitting on.
you can see from the right side photo it actually looks a little nose high (both truck and trailer)
I only measure the truck on the left side, but now looking at these pics I should have measured both sides.
I'm not sure if I need to adjust the nuts that position the cam into the detents on the Reese Dual Cam setup since the hitch and the trailer are the same? only the truck changed. I was going to loosen the nuts and do a few figure 8's in the lot and then tighten them back up, but I didn't have a wrench big enough for those nuts (anyone know what size they are?)
Also I'm using 1200lb bars.
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
