- ksg5000ExplorerIf it doesn't the likely cause is problem with converter, blown fuse between battery and converter, or bad battery. Lots of threads on how to test converter and auto reset fuses.
- bguyExplorerIt should, generally speaking. I was told to expect 24-48hr charge time. I would imagine this assumes a good battery. BTW, if you remove the caps and can see the top of the plates it will never hold a charge. If you find this to be the case water it up and look for corroded ground to the trailer frame. A poor ground set up can cause your battery to boil out by overcharging as the excess voltage if force fed.
The other possibility is that you have a bad battery.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 16, 2025
