down_home
Nov 17, 2015Explorer II
Ours like most, I suspect are pretty tight.
Cold outside, warm inside and people breathing, furnace and moisture drawn from around gaskets will condense on windshield any other surfaces, especially metals.
A dehumidfier is about the only real way, over weeks and months to protect it.
Set moisture level on unit and hose into sink or shower drain etc. Set the unit on a solid surface away from anything that might combust. There is always a chance with anything electric.
Cracked windows and letting the inside rest at close to outside temps will certainly help but there will still be too much condensation.
The reasons fabrics and cushions smell musty after being stored in the humid environment is they are musty and moisture condensed to some extent on and in them.
Perhaps some Manufacturers build a dehumidifier in but I don't know one.
We have as most had to turn on coach engine and let dash air/hear run to clear up windows and windshield etc, while parked.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
