dcmac214's avatar
dcmac214
Dawn vs Laundry Detergent
Latest Dawn/dish detergent post got DW to thinking (I know, that's a bad thing but I couldn't stop her): Would laundry detergent be better for holding tanks? It's made to cut grease and just about everything else if you can believe the ads; it's low- to no-suds; and volume-wise it's quite a bit cheaper than dish detergent.
  • John&Joey wrote:
    Key words "cut grease." You need your blade to slide easily when you pull it. Last thing you want is for it to stick to the rubber seal and either pull it out or just get stuck.
    All these VooDoo tank cleaning schemes, might just bite you in the ...
    Would you also worry about a roughly equal amount of soap and detergent that gets into the gray water tank from dishwashing, laundry, bathing, etc.?
    The rubber seals on the valves are not greased, so far as I am aware; they get sticky or wear out or leak or break mainly due to age.
  • Key words "cut grease." You need your blade to slide easily when you pull it. Last thing you want is for it to stick to the rubber seal and either pull it out or just get stuck.
  • To each his own. If some people don't think that its necessary to do anything but add water and use their facilities then fine, its their trailer. I tend to think a little bit of prevention and attention to how well my tanks are draining and I don't mind spending a little bit of my money on laundry detergent and Calgon to help my tanks drain for my peace of mind, weather anyone else thinks I am fooling myself or not. I use the GEO Method and have been satisfied with the results.
  • Two gallons of water and a cup of Tide laundry soap.
    Every time after I do that last dump before the drive home.
    No clogs, no smell.
    Cheap insurance.
  • TenOC wrote:
    I do not know why people want to clean holding tanks. A few gallons of water left in the tank and a few miles down the road with the water sloshing around and the tank is clean.
    Well, because I have repeatedly succeeded in cleaning level gauge sensors with water AND a small amount of liquid laundry detergent sloshing around while rolling down the road. Water just didn't do the job as well.
    Not really sure why you ask why people would want clean tanks, then provide a method for doing so? I had a coworker who got a good deal on a private sale used Travel trailer. The original owner apparently didn't see the need for cleaning the tanks. For some reason the black tank had several inches of hard crusty solids, and the clean out was pretty unpleasant. Given that a half full drywall bucket of water and a shot of clothes soap can leave the tanks looking spotless, if done regularly after dumping, I'm not sure what the issue is.
  • I do not know why people want to clean holding tanks. A few gallons of water left in the tank and a few miles down the road with the water sloshing around and the tank is clean.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 08, 2025
