Aridon
Mar 19, 2017Explorer
CA Traveler wrote:
Yes you can take the receiver with you as long as it's not a Genie Client which is NOT a receiver. However once you travel several hundred miles you will leave the local spot beam and no longer get the national channels. If you call and get the local channels for the rig then the home receiver will no longer get its local channels.
If someone were to fall under this one option is to "move" to NYC or LA area. Pick a fake address, apartment or condo and add a number or letter to it. This will net you the CONUS locals and you'd have access to at least all your network programming, minus your local news naturally as that would be NYC.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
