- wannavolunteerFExplorerI guess I am paranoid.. I use 4 wheel chocks -- in front of front tires and behind back tires. I bought rubber ones at Harbor Freight and like them much better than plastic.. I can wedge them using boards or lego blocks.. I then add between the wheel after I get set up if I am staying more than one night.. usually give the tires time to cool and check the rubber ones and tighten the between the tires.
- MarkTwainExplorerNever had that problem. I don't need chocks unless I am parked on an incline or decline.
Roto Chocks keep the trailer more stationary when people are walking within the trailer. - bikendanExplorerthat's why most of us use tandem wheel chocks of some kind, on BOTH sides. just using plastic wedge chocks is just asking for trouble.
- luvglassExplorer
fj12ryder wrote:
I use the RotoChoks between the tires. They work regardless of whether the tires are on leveling blocks or not. And I chock both sides unless it is just a quick overnight stop and the site is very level or we stay hooked up to the truck.
X5 :) - MartynNomadBoth sides always - get some Rotochoks
- DutchmenSportExplorerBoth sides always --- always.
- wandering1ExplorerNever had that problem. I don't need chocks unless I am parked on an incline or decline.
- MrVanExplorerIf you use enough leveling blocks or adequately long boards you can still chock both sides. The chocks then set on a leveling block at the same height as the tire. I have found that using the TV to tighten up the front axle chocks by pulling against them while inserting two rear axle chocks up tight is almost as good as putting the wedge between the tires on each side.
- MarkTwainExplorerI use the RotoChoks between the tires. They work regardless of whether the tires are on leveling blocks or not. And I chock both sides unless it is just a quick overnight stop and the site is very level or we stay hooked up to the truck.
X2
X3
First I do my side to side leveling while still hooked up by placing the necessary # of levelers. Then I install the RotoChocks. If only overnight, then just one side, if for any extended of time, I install RotoChocks on both sides. I am not real impressed with those plastic chalks before and after the tires as there is no direct contact with any real pressure against the tires. While traveling and temporarily stopping i.e. Rest Stop where I have to leave the Diesel engine running to cool down and I don't want to trust just the emergency brake on the truck, I just put a 12" piece of wood 4x4 before or after the tire. I attached a strap to the block to place or remove it and then just throw it into the bed of the truck when done. works for me:) - Dog_FolksExplorer III only chock one side.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
