rbp111
Sep 24, 2016Explorer
BigSur2 mentioned that he has a portable propane heater that is safe to use inside the trailer. I have a Mr. Heater-Big Buddy which I use in my fifth-wheel trailer. I would advise BigSur2 that is the way to go. You can utilize the devise which refills the small propane tanks from a larger one, say a 20lb tank. That is much cheaper than have to purchase the small tanks. Or he could do what I did, that is have a quick connect put in the trailer and go directly to the two 30# tanks.
I would recommend a the use of the portable propane heater because, in my case, it has a battery (3 D cell batteries) which operates the fan. And if you don't have the fan, that is ok, it still heats up the trailer in time. But as the people have said before me, the trailer heater will use up the battery power in no time.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 28, 2026
