Kevinwa
Sep 29, 2016Explorer
If it is cool at your home you can run a simple test as to how long it can last with the furnace running.. unplug the power cable and turn the furnace on for the night, set the furnace uncomfortably high so it is forced to run most of the night. Go to sleep and the next morning check your battery level. If it is a single night stopover without power and your next night is powered then you don't have to worry about how low your battery is in the morning, as long as you make it to morning.
Just remember on your stopover night to unplug the camper from the tow vehicle, so you don't drain that battery by morning. It would suck to be stranded with a dead truck. This of course doesn't apply to fords, as they have a relay that shuts the charging cable to the trailer off with the key.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 13, 2025
