boostedone
Mar 23, 2015Explorer
Dometic 2652 Cooling Unit Replacement
Well, where to start...
Last season I left my camper at a campground to use on the weekends. After not using it for several weeks I went to pick it up, and found the fridge not cool. It was lit, and "running" on electric, I never use it on gas. I figured maybe one of us just forgot to shut the door all the way. I brought it home, plugged it in and checked a few days later, still warm.
Anyhow, I mentioned it to a friend of mine who said its probably the heating element. Due to a bunch of other things going on, I just filed that in my mind. Now that its getting nice out again, I want to use the camper soon so I went yesterday evening to trouble shoot.
Well, now the fridge lights are off. Checked power feeds, all good. I found the problem is the thermo fuse, which I found was part of some recall. Also found the heating element to have 40 ohms resistance so that was good..
I bypassed the thermo fuse and everything powered up fine. Unit would run on gas, heating element worked on electric.
My problem is, there is yellow deposits all over the solenoid area.. From what I gather, this means my cooling unit probably sprung a leak, discharged, lost cooling, and then in time the heating element got so hot that it melted the thermofuse.
Now I am looking for a cooling unit. I see the Amish units have a good rep, and David Force is the man to get them through? Do his units come with all thats needed to put it in? I saw a video online to replace the unit, and it mentioned a special caulking to transfer the heat to the box.. Does davids units come with that? Also, just what is the difference between the new and reman'd units? Is the new that much better?
I am trying to figure out all I need to get the job done the first time.
Also are there any other worthwile upgrades or things I should do when I have the fridge out? I see David sells a bunch of fans and stuff like that, an adjustable thermister, etc.
Sorry for such a basic question, but I feel like i am getting blasted in the face with a firehose by googling. I think half the hits for new units are multiple domains run by the same guy, and I also want to make sure I dont buy an imposter unit from some guy thats importing******from China and cut and pasting the real info on his site.
