Ro646a's avatar
Ro646a
Explorer II
May 25, 2017
Dometic 2652 stops cooling after 4 days
My friend has 2000 Class C RV with the original Dometic 2652 refrigerator. When he first turns it on, on either 120 or Propane it cools just fine, but after 4 to five days it stops cooling. The fridge is still getting power, and the gas is on, but will not cool again until he leaves it off for a few days.
Has anyone ever had a problem like this?
Thanks
  • Just went through this with same fridge only 1996. Fridge had always been run on AC only so was really clean burner area. Lit beautifully with nice flame. Ran anywhere from 1 day to 3 days, then quit with check light. My initial thought was the control board was bad, but trouble routines on this and other forums suggested that was unlikely. Went through various trials and tests, then fuse blew on board and it would not ignite at all. I tried to have board tested but my local RVdealer said he could not test it outside the RV. I finally decided to just replace board. As I had in the past replaced both my water heater, then my furnace boards with Dinosaur boards and found them excellent I went with a dinosaur. It's been installed now 5 days and so far my check light has not come on. Knocking on wood, but I wish I'd replaced the board first thing.
  • Does your friend also have a dead battery at the same time? Refer needs 12 volt to run the control board.
    LEN
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
