buc1980's avatar
buc1980
Drain master hose
Anybody use this sewer hose which cost 130$.Looks good but how you use it on regular bayonet connection.You got to modify(CUT) the FW CONECTION TO MAKE IT FIT.
  • The connectors are cam type that are used by commercial septic pumpers, and the hoses are pretty heavy. It's a very nice system, but it is not compatible with the standard connectors used today.
  • A hose is a hose. If it drains and doesn't leak, how can it "do the job better"? Plus you have to modify to make it work? No thanks.
  • buc1980 wrote:
    Check the internet and you will see.It looks good and it do the job better
    Really - just what is it?? Link??
  • Check the internet and you will see.It looks good and it do the job better
  • That's an expensive stinky slinky. What makes it better than a Rhino hose?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
