mrekim wrote:
I'm positive we got to 50 degrees on a right hand turn many times. That's just a normal turn.
Is it possible that the bent style brackets that connect to the DC arm are "better". Does it seem like they would move the load inward - maybe reducing the amount of force pulling down on the DC frame mount as well as moving the chain inward so it's less likely to go "over center" on the snap up?
Yeh, with a compound angle turn it does not take much difference in truck surface to TT axles surface angle to create all the load on one WD bar, and the turn of any degree escalates it. If the truck is going up hill in relation to the TT and turning on uneven ground, the WD load goes even higher until the back of the truck lifts up to semi equalize the load. We have sort of nick named this up hill effect, "backflex" in the hitch. The kind you get coming up and over one of those real nasty high up Railroad crossings.
Until one starts really studying how a hitch head manipulates itself around and what is going on in the WD bars with changing head angles just towing down the road, one never realizes how much the forces move around constantly in most any kind of turn up and down hill action.
The bent chain keeper plate verses the straight and does it change the loads on the snap up any? For reasons not yet understood, Reese has gone in and out of bending that chain plate. During the 2010 year time frame they did some design tweaks to the HP Dual Cam. And they also changed where it was made or at least some of them. I have the 2nd generation DC that was created back in the year 2000 ish time frame and it has the straight plate. Colors re gold. Then they starting around late maybe 2009 into 2010 the bent chain plate started showing up on new hitches, still gold, but they did not yet have the new redesign DC arms of the 2010 3rd generation which are silver and black and the Yoke is really different.
Why the bent plate? I “believe” do not know for a fact, they where trying to get the chain force more vertical. The original style DC had a clevis clamp that pulled on center of the cam arm. That vintage DC arm allowed that. However the frame brackets used long U bolts over the frame. This center action created chain pull more like a non DC WD hitch with the chain attached to the WD bar.
I do not know all of them, but following RV net on hitches since 2003 most of the reported snap up issues come when the DC is involved and they “seemed” to start showing up when the new 2nd generation DC arms that bolt direct to the frame started to be sold. Again this same year 2000 time frame is when digital cameras and the gaining popularity of camping forums of people reporting issues was on the rise to even hear about the problems. It is a fact the chain plate is pulling the cam arm on a slight angle verses the older clevis style. And it appears as long as the snap up bracket stays held dead tight to the frame the issue does not rear it’s ugly head so much. Thus the belief the bent chain plate was an attempt to get the chain forces more vertical to help this issue.
I now have seen the straight flat chain plate come back on the scene in a hybrid vintage just like yours. You do not have the DC adjusting arms/yoke of the 2010 design tweaks that had the bent chain plate yet your yokes are different than mine. Look at them closely. You also have a non machined cam arm where mine is machined in the cam area. So why didn’t; Reese just put the bent angle chain plate on yours? That is a real good question.
It may have been that people did not realize there is a right way and a wrong to hook them up. The angled plate for sure can create an issue put on wrong and it really aggravates the problem. The straight plate can still be flipped wrong, but the effect with U bolt thread in or out is not so pronounced.
I can see the bend slightly reducing the chain angle from vertical as opposed to having a straight plate. However since the DC arm is still only held on one side, there is still a cantilevered effect and a side pulling load in the chain regardless of a straight or angle plate. It could be less on the angled plate than the straight. That said, I do not feel the angled plate is going to totally solve the issue even if it helps it some percentage. I do not see that the angle hurting the situation so the angle should be a good thing, just make real sure it is installed correct.
To help spot the design changes, look at the colors of the parts as this seems to come along with the changes for the most part. The yoke and cam arm gold colors (zinc chromium oxide coating I believe) are the year 1999 to 2000 2nd generation. The silver cam arm and the black yoke are the 2010 vintage 3rd generation design tweak and yours, well it is silver and black but yet looks similar to the older gold one and has straight chain keeper plates. I can tell they are made from a different casting mold.
So that is the history. If you have a really large vise, it is not that hard to create angled chain plates.
PS I'm going camping for 3 days so may not be back for a bit.
