schlep1967
Jan 31, 2017Nomad
hattis1 wrote:
don't know haven't bought a mh yet. still looking. vegas is one we are considering.
First you would want to check you manual for the Edge as to whether it can be towed on a dolly. Or you can ask Ford. Then if it can be towed you would need to know the weight of the Edge. And then you would need to base the RV you buy on its ability to tow that weight.
Research ahead of time will save you headaches in the long run. And while there is much help to be had here your Edge may not be equipped the same as someone else's Edge. Sometimes you just have to do your own leg work to be sure you get the correct answers.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
