scout_dad's avatar
scout_dad
electric jack
Hi I am thinking on getting a new jack this season my question is there much difference on the 2500-3500 lb electric jacks other weight? MY rig is a 2006 Crossroads Zinger 2710 BH , would a 2500lb work or would it struggle to lift? I am not sure what my tongue weight is?
Depending on where you buy and what brand, their is a price difference range?
I am would like the ease of electric but what I hear seems people only get about 2 yrs out of them?
any thoughts,
Thanks
  • Hondavalk wrote:
    downtheroad wrote:
    Just keep in mind that you are not only lifting the trailer tongue but you are also partially lifting the rear of your tow vehicle. (not lifting it off the ground)...to alleviate some of the tension on your hitch's spring bars when you hitch up and un-hitch.
    The 2500 will work just fine, but I'd go for the 3500 for just a few dollars more. It's a stronger unit all around and will last longer.
    Well said :)
    x2
  • A 2500 lb tongue jack is likely to have a 2" shaft, a 3500 lb would in most cases have a 2.25" shaft ... considering the size of the OP's trailer surely it would have a 2.25" hole in the A frame. JMO, but it doesn't make any sense whatsoever to go with the lighter jack, particularly when the price difference is so insignificant. Just two years use out of power tongue jack? ... that would be news to me, I've been running power tongue jacks for years and haven't had any permanently self destruct. Yes, my UltraFab dropped the lower shaft one time when a locking pin backed off but I simply put it back in using Locktite and never had any further issues with it at all. If there is any recommendation I would have it would be to cover the tongue jack head with a cover to minimize discolouration of the head (which in many cases is plastic) from the effects of the sun and to prevent water from getting inside the head. If you have a tailgate interference problem look for a tongue jack on which the head itself can be rotated 180 degrees relative to the shaft ... the UltraFab series would be a good example. The head on my current LCI tongue jack does not rotate and it's a real PITA as it interferes with the tailgate on my Avalanche which is taller than most 1/2 ton truck tailgates. I'd swap it for another UltraFab but (unfortunately) the LCI continues to run just fine, giving me little justification to spend the $$$. ;)
    Well said :)
  • I got at least 15 years out of my last elect jack. Used on three different TT
    3500 Atwood
  • Just keep in mind that you are not only lifting the trailer tongue but you are also partially lifting the rear of your tow vehicle. (not lifting it off the ground)...to alleviate some of the tension on your hitch's spring bars when you hitch up and un-hitch.
Looking for advice before your next adventure? Look no further.25,152 PostsLatest Activity: Aug 01, 2025
